InfraWorks General
Message 1 of 4 (678 Views)
Scale in AIM
678 Views, 3 Replies
02-11-2013 03:16 AM
I create a file in Autodesk Infrastructure Modeler, import the surface (LandXML), then import the center lines of railways (DWG). Configures the surface and railways. Then measure the distance between the two center lines Railway in Autodesk Infrastructure Modeler and AutoCad Civil 3D and I can see that the sizes do not match. Help, please!
Civil 3D
AIM
Distinguished Contributor
Message 2 of 4 (654 Views)
Re: Scale in AIM
02-11-2013 05:31 PM in reply to: RavchukNA
One thing you could do is draw a grid of lines in acad 10' apart.
Then plot as jpg or pdf (then convert to jpg), and bring into acad.
Make image to scale, and make the world file (jgw).
then Pull that image into AIM as a reference, and do the dimension test.
Then we will have an idea if AIM is doing things right.
I say this becase I have had no problems with images lining up with surfaces in AIM.
Since that part of the prog seems predicatbler and well behaved, we must check if its scaling things or not.
I have many of the same questions, as there is no way to draw a line from some coordinate in AIM, to verify anything.
Correct me if wrong, as that ability would be the first way I would check scale stuff like this.
Message 3 of 4 (639 Views)
Re: Scale in AIM
02-14-2013 07:01 AM in reply to: RavchukNA
3d dist.jpgI can't read the distance in your AIM screen shot, but keep in mind that the distance you are seeing in the dwg is 2 dimensional.  Then, when you import it into AIM, it will follow the surface and when you measure it, it will be different.  I just did a test and confirmed that the AIM distance is the hypotenuse of a triangle defined by the 2d length in the dwg and the change in elevation between the 2 railway endpoints.
Scott Kent P.E.
Senior QA Analyst II
Infrastructure Collaboration Products
100 Commercial Street
Manchester, NH  03101
Scott Kent P.E.
Message 4 of 4 (531 Views)
Re: Scale in AIM
03-05-2013 06:15 AM in reply to: scottkent
Thank you very much but the problem was in the coordinate systems.
You are not logged in.
Ask the Community
