Hello all,
I downloaded the trial. Because I really want to check what this application is about.
However, there should be a road module in which you can modify the vertical profile and so on...
Where is it?
I can not find any information about this in the Help from Autodesk
Greetings, Renzo
The road module is only available in the Infrastructure Design Suite Ultimate. You'll need to download the trial of that in order to get the road tools.
Hmmm, thanks for your quick answer.
Rather disappointing.
We have Premium here... However, upgrading to this for only this module is crazy.
This is a problem caused by all these Suites from Autodesk.
@Autodesk: are you changing this strategy?
Greetings, Renzo
The only trial version available is the Ultimate edition. So if you downloaded the trial version from Autodesk's website, then you have the Ultimate edition. The profile stuff is under the Optimize tab of the ribbon.
Hello all,
I did not know that there are differences for InfraWorks.
It is confusing.
So you see something during presentations but can not re-produce it.
Now I know I have to use the Ultimate edition for that. Thanks for your answers
But still that is a lot of money for one extra module...Too bad
Greetings, Renzo
@trogers wrote:
Brian,
I didn't even think about the standalone application. They are drilling these suites in our head with this migraton. First we had to call all our customersand tell them, then, ka-pow, had to do it all over again. Thanks for the heads up.
You put your "Opt-in"
You put your "Opt-out"
You put your "Opt-in" and
You shake it all about...
