Hello everyone,
Before we used Infrastructure Modeler 2013 to create the model, everything was nice and easy to do. Last week, we updated to Infraworks 2014, there is a big issue that everything under the image surface cannot display. If we disappear the image, we can find the river or road. But if we use terrian image, they will be covered and no see.
Should we do some special config in 2014?
thanks.
Tristan Yao
Could you provide more info about "everything under the image surface".
Are we talking about imported data here? If yes, what type of data is it (2.5D, 3D?) and which draping option did you use on the import. If no (i.e. these are drawn features), what kind of feature types did you draw?
And last did you changes specific properties of the features that are disappearing (changed their height using the height grip, changed some non-geometric property using the property inspector)?
Also, did you try to move the layer containing your Ortho-Imagery down to the bottom within the "Ground Imagery & Coverages" group of the "Manager Surface Layers" dialog (acessible via Model Explorer > [Right-MouseButton-Click on] Surface Layers > Manage Surface Layers)?
Sascha
