I have just loaded the 2014 Infraworks and dont have a Corridor tab under View like everything I read online, is there a toggle or something that will get me it and I'm also missing the Optimize tab. any thoughts.
Mike
That is a module that is only available in the Infrastructure Design Suite Ultimate.
the optimize tab is only available with the Roads & Highways module which is only available with Infrastructure Design Suite Ulimate 2014 with sub
http://www.youtube.com/watch?v=mwOIkETDS3M
DarrenP
i would have to check on the corridor tab
DarrenP
this doesn't have the corridor tab either: http://www.youtube.com/watch?v=e_D4zJytPkA
DarrenP
Schroeder.a, I appreciate your passion about this. You don't have to buy IDS-Ultimate and Revit. Roadway Design for InfraWorks 360 Pro gets you access to profile (vertical) optimization. (And, of course, you can export your results into Civil 3D format.)
neilyj (No connection with Autodesk other than using the products in the real world)
