Hi RavchukNA,
I'm not sure why the pylons are missing in your case. I can confirm though that if the pylons are in the model that created the scenario when it was published then they should also be in the resultant scenario.
Regards
Tom
I have an update. There is a problem in the viewer that is causing the problem you are seeing. We are currently working on a fix for the issue.
Regards
Tom
