have you tried contacting your reseller?
DarrenP
your company probably bought the software from an Authorized Autodesk Reseller any support goes through them and they pass it off to autodesk if they can't help you
DarrenP
but if its just a serial number issue
try calling Autodesk Activation dept @ 1-800-551-1490
DarrenP
all customer service/support is all through the reseller channel and usually not directly through autodesk unless your company has some sort of agreement with autodesk
DarrenP
Licensing is done as a separate module at Autodesk and so I'm not sure if you will get much support from this list from Autodesk (who I think are mostly focused on the core product). I did a quick search of our autodesk.com site and under the support tab there is a section for Installation & licensing that seems to have some documentation. And from there, there is also a pointer to an installation and licensing forum: https://forums.autodesk.com/t5/Installation-Licensing/bd-p/24. I know that this doesn't answer the problems that you are having, but perhaps the above forum will have some pointers in case the activation that DarrenP suggests doesn't work for you.
