Hello!
Tell me, please, how can I create my own vehicle to the intersection?
Solved by tcorey. Go to Solution.
How are you getting to that dialog?
I created two design road with intersection and selected new object - a crossroad. How can I create my own vehicle to the intersection?
I have found this file:
C:\ProgramData\Autodesk\InfraWorks 2014 R2\Resources\Standards\Roads\Common\Rules\IntersectionDesign_Rules.clp
which can be edited with Notepad. Part of this file includes reference to VehicleType.
If you like to dig through the program, that's a starting point. I'm going to look a little deeper, but I don't know if I'll be able to provide an answer. I hate to say, "It can't be done," but I might end up having to say, "I can't do it."
I think I found it:
C:\ProgramData\Autodesk\InfraWorks 2014 R2\Resources\Standards\Roads\DesignStandards\Intersection_AASHTO_Imperial_2011.clp
(or the metric version.)
The contents of the file specify the various design vehicle names and the mid-curve radius to set based on the turn angle. This info should get you to where you can make changes to the design by adding your vehicles to this file.
Please note the copyright at the top. The way I read it, you need to get written permission from Autodesk if you want to modify this file.
If you are able to accomplish this feat, please be sure to follow up to this thread.
Sorry, but due to the copyright notice, I'm can't go any further with this.
Good luck!
Tim
neilyj (No connection with Autodesk other than using the products in the real world)
To RavchukNA's comment I would add that the design vehicle rating selections for intersections are now available to InfraWorks 360 Pro subscribers with Roadway Design for InfraWorks 360 Pro as well. (By the way, this functionality works with intersections of design roads, not with the basic ("spline") roads that come standard with InfraWorks.) For more about the rule-based intersections, see our blog post at http://autode.sk/152AttS.
@ Todd re buttons: In InfraWorks 360 Pro with Roadway Design, on the ribbon, you should see Home > View Civil 3D Drawings. Clicking the View Civil 3D Drawings button opens a 3-page wizard that says "Create Civil 3D Drawings" at the top. When you reach the third page of the wizard, the button for placing the order is "Generate."
(If you do not see these things, it means that you still need to activate Roadway Design from within InfraWorks. To do that, close your model without exiting InfraWorks. On the left, under "Vertical Applications," click "Activate Roadway Design" and follow the prompts, which will ask for your credentials.)
The help topic on this is at http://help.autodesk.com/view/ICD/2014/ENU/ at Roads and Highways > To generate Civil 3D drawings of design roads.
have the infrastructure design suite ultimate installed with subscribcion and yet I can not create intersections, is there to do some kind of configuration? or How I can solve the problem? thanks
