InfraWorks General
Product Support
Message 1 of 26 (1,937 Views)
Infraworks 2014 - Component of Autodesk Infraworks 2014 has stopped working.
1937 Views, 25 Replies
05-14-2013 06:29 AM
When starting Infraworks - I get this error:  Component of Autodesk Infraworks 2014 has stopped working.
AIM 2013 also has the same error.
AIM 2012 does work.
Coult this be the issue?
http://forums.autodesk.com/t5/Autodesk-InfraWorks/AIM-2013-not-opening/m-p/3823563
David Lau
*Expert Elite*
DarrenP
Message 2 of 26 (1,925 Views)
Re: Infraworks 2014 - Component of Autodesk Infraworks 2014 has stopped working.
05-14-2013 06:46 AM in reply to: david.lau
it could be
i can't seem to log in to AIM 360 account from Infraworks 2014 but starts up fine
with 2013 yes that could be the problem if your using 2013 r2 there is this hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20979998&linkID=17838076
Employee
lippola
Message 3 of 26 (1,859 Views)
05-24-2013 05:06 AM in reply to: david.lau
Hi guys,
just wonder if this has been resolved or if new information on this issue came up?
Andreas
*Expert Elite*
DarrenP
Message 4 of 26 (1,851 Views)
05-24-2013 05:51 PM in reply to: lippola
no idea
Message 5 of 26 (1,610 Views)
08-02-2013 06:41 AM in reply to: david.lau
I am currently having the same issue.  Worked yesterday morning, then tried it in the afternoon and it stopped.  Did anyone find a solution for this?
Active Member
dburkard
Message 6 of 26 (1,512 Views)
08-09-2013 08:12 PM in reply to: david.lau
Has anyone or Autodesk found a solution.  I can't even start this program.
Product Support
Message 7 of 26 (1,484 Views)
08-12-2013 06:28 AM in reply to: david.lau
Can you let me know if Infra Structure Modeller 2012 worked?
When the 2013, 2014 version came, the application was rename to aim.exe which is the same as AOL messager which may be a banned program in company.
http://forums.autodesk.com/t5/Autodesk-InfraWorks/AIM-2013-not-opening/m-p/3823563#M692
Other than that, you need to also confirm that your video card is supported as well.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18630064&linkID=17838075
http://docs.autodesk.com/ICD/2014/ENU/system_requirements/infraworks-sys-reqs.htm
David Lau
Message 8 of 26 (1,458 Views)
08-13-2013 03:27 PM in reply to: david.lau
I uninstalled my video card and reinstalled it, the program opened as normal.  I recently dumped my old Nvidia cards in favor of an AMD Firepro, seems to really do the trick.  But if you are having this problem, try to unistall and reinstall the video card and drivers.
Valued Contributor
Message 9 of 26 (1,384 Views)
08-19-2013 10:46 AM in reply to: enelson
I am having the same issue also. InfraWorks 2014 r2 was working fine for the first 2 days then windows did some updates and now it's crashing as soon as I open it. I get the same message that Infraworks component as failed. I have uninstalled it then reinstalled and it still does not work. Am going to try to revert my video card update to see if thats is the problem.
Tony
CAD Manager
AutoCAD Civil 3D 2013 Certified Professional
www.tonyscivil3dworld.blogspot.com
Active Member
dburkard
Message 10 of 26 (1,380 Views)
08-19-2013 10:54 AM in reply to: david.lau
2013 worked fine, and all the rest of the ultimate building suite 2014 works just fine.  It is just the Infra Structure that is not opening and coming up with the message.  It seems strange that Autodesk would re-deisgn or program a piece of software that all the sudden needs different video requirements then the rest of the package.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
