InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Import/Link Revit to Infraworks
11 REPLIES 11
Message 1 of 12
bolduc.steph
4842 Views, 11 Replies
I've been hearing that Infraworks now possesses the ability to import Revit (.rvt) files directly into Infraworks.  If this is true, it would save me hours of time worth off of file conversion, and hopefully give Infraworks the ability to query the BIM data associated to the models.  Could anyone provide me with any leads? Heard that the feature is only available in the "Infrastructure Design Suite Ultimate" but not in the "Building Design Suite Ultimate", which is the one I have.
Cheers
11 REPLIES 11
Message 2 of 12
That is correct.  It's there now...
Todd Rogers
Message 3 of 12
Good to know! I guess that means I don't have the right version of Infraworks 2014 installed? The "Revit RVT" option doesn't appear in my dropdown menu. What design suite are you running? Infrastructure? Thanks for the heads up!
Message 4 of 12
Interesting.  I'm running the Infrastructure Design Suite Ultimate.
Todd Rogers
Message 5 of 12
That's what I figured. I'm running the "Building Design Suite Ultimate".  I've been hearing the the 2 version differ from the "Infrastructure" and "Building" design suites.  Ridiculous that they aren't running the same versions with Revit compatibility.  I work at an architectural research lab that deals with large BIM models, very often situating them in the broader urban context.  Up t'ill now we've been resorting to .fbx files to load our models into Infraworks, but were excited to hear .rvt files finally being supported. Finding out now that the "Ultimate Design Suite" is missing that 1 key feature that we've been waiting for just doesn't make sense to me. Any ideas on who I can contact to acquire the version that you're running?
Cheers, and thanks for the help!
Message 6 of 12
You can acquire it from us if you like Smiley Happy.  Contact info is at www.tcadsys.com
Todd Rogers
Message 7 of 12
Our lab has just upgrated to 2014 hoping that it would provide some solutions to the revit import problem, so I'm really hoping that Autodesk will just swap the versions since we already paid for the package
Message 8 of 12
Call us and we can look into what it will take to get you converted over.  Do you already have a reseller?
Todd Rogers
Message 9 of 12
DarrenP
in reply to: ToddRogers-WPM
this is a known issue with the building design suite ultimate 2014
you can always export to fbx from revit
DarrenP
Message 10 of 12
bolduc.steph
in reply to: DarrenP
I just downloaded the trial for Infraworks (Infrastructure design suite Ultimate) just to see the difference.  The feature isn't actually as good as I thought it would be, but it does carry all the textures much better than .fbx files because they don't have to be in a seperate folder.  With the revit import options, I was hoping it would behave more like revit files would in Navisworks where you can select individual members and at least query basic information.  Was also hoping to be able to filter out certain layers such as topography and masses when importing, but it doesn't look like that's possible either.  The main reason I was really hoping to see this functionallity was to have a more unified and efficient workflow between software packages, ie. make a change in the Revit model, change appears in Infraworks upon update.  I'll continue to test the feature to see if it's worth switching, but for now it almost doesn't look worth it.
Message 11 of 12
Hey Steph.  I got a response back from Autodesk on this.  They said that they are fully aware of this and are currently working on this.  They are going to release an enhancement for the BDS edition of Infraworks and the option will be there.
Todd Rogers
Message 12 of 12
That's great news!  Good to know that they are planning a patch for it, avoids us having to switch software packages. Thanks for looking into the issue, much appreciated.
Rail Community
