InfraWorks General
Member
Message 1 of 2 (181 Views)
How to project work to raster Terrain Surface
181 Views, 1 Replies
11-27-2013 06:33 PM
I had imported the Terrain model as a vector import and notcied after I got done putting in 75% of my proposed parking areas, landscaping and roads that I should have used the Raster image for the terrian model.
So I imported the raster terrain and I got the enclosed look and feel. It appears that all my work is set at 0 elevation and it looks like it is sunk into the ground. How can one reproject the work to the raster ( true surface) without starting over?
ADN Support Specialist
Message 2 of 2 (154 Views)
Re: How to project work to raster Terrain Surface
11-28-2013 10:50 PM in reply to: mongoosest3
Check the "Drape Options" of the Data source and you can play with the 'Set Elevation' vs 'Drape' to see if that helps to set them appropriately.
Partha Sarkar
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
