I had imported the Terrain model as a vector import and notcied after I got done putting in 75% of my proposed parking areas, landscaping and roads that I should have used the Raster image for the terrian model.
So I imported the raster terrain and I got the enclosed look and feel. It appears that all my work is set at 0 elevation and it looks like it is sunk into the ground. How can one reproject the work to the raster ( true surface) without starting over?
Check the "Drape Options" of the Data source and you can play with the 'Set Elevation' vs 'Drape' to see if that helps to set them appropriately.
Partha Sarkar
