InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Fatal error at opening file due to lost path for textures
2 REPLIES 2
jmanders
538 Views, 2 Replies
When opening a file I get a Fatal Error because the "TileCacheRenderer\MainCache.ccp" can't find the path to several used textures.
the message I get is this: " Exception in MainCache worker: boost::filesystem::last_write_time: "
I imported several Sketchup Models and AutoCAD FBX exports with textures and both are causing this problem.
any ideas
2 REPLIES 2
wilsonm2000
in reply to: jmanders
I know this is an old threwad, but I was looking for a fix, and seen this comment, but no answers.  I have eventually found the issue.  I think you get this error message if the path is too long.  A colleague copied the files of my model folder straight to his C: drive folder and opened fine with no errors.  So I done the same, and works fine now.  Hope this helps others 🙂
Eric_Chappell
in reply to: wilsonm2000
A great find, bigmaz. Thanks for sharing! I've forwarded this information to our product team.
Eric Chappell
Rail Community
