Hello everybody,
I have the following problem.
I have a form with a check box, which indicates if the feature needs to be payed or not. If the checkbox is set to TRUE, the control (textbox) next to it, should be enabled in order to add a price. If it is set to FALSE, the contol next to it should be disable and it's value should be set to "0".
I suppose all this is possible with some VB code in the "validation code" property of the checkbox, but I couldn't find anything on this topic, which helped to solve my problem.
Does anybody could help me on this one?
Best regards,
Bob
Since AIM does not support VB scripting, I think this probably belongs into one of the MapGuide groups here: http://forums.autodesk.com/t5/Additional-Product-Forums/ct-p/1 ?
