InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Display dashed lines on relief
1 REPLY 1
Vanitos
804 Views, 1 Reply
Good day to all.
Well... I've build a model of relief.
Than I've learned to load polygons (from SHP-files) on relief to display them AS POLYGONS. (used type - coverage areas). Also I can change the style of polygons..
And now how about LINES? I have SHP-file with lines and want to display my lines on relief AS LINES! But I can't find any type for it! There are coverage Areas, Pipelines... but it is not correct type for me.
How can I display SHP-layer with lines AS lines on relief?
And second... how can I change style of the simple lines to dashed lines?
It's very important..
1 REPLY 1
You can import your lines as "coverages" and use the "buffer" property of coverages (specified in length units, e.g., meters) for turning them into (thin) polygon; dashes and other stylization patterns are not supported right now.
Konstantin.B
Software Architect
Rail Community
