Hello!
I have defined a new coordinate system in Civil 3D and I want the coordinate system to be in AIM Library.
Heellp
Hi there,
Civil, Map and AIM are using the CS library as a shared component. So if you have defined a specific CS in Civil it should be visible in AIM as well. Please check this out and see if it works alright, since i haven't used it yet.
Andreas
I'm having the same issue with Map3D. They are supposed to use the same libraries, but they don't. A coordinate definition that is in Map3D that was created through Map3D does not appear in the list of definitions in the AIMS library.
How do I get them to appear in AIMS. So frustrating.
I found the solution. Turns out if you have Map3D installed on a different local drive than where AIMS is installed, it won't see the coordinate definitions. (I have a local c: drive and a 😧 drive)
After installing Map3d on the same local drive as AIMS studio, the libraries shows up.
