I am unable to add city furniture to my model. I know the proper procedure because I can do it in the tiny town model. But when I try to do it in the models I create, I am able to draw the line segment but nothing ever shows up. The only way I have been able to get around this problem is by drawing a building and then changing the style to a car or person or some type of furniture. I can add buildings, roads, rails and water fine, but not furniture. Is there some setting that may be blocking the furniture from coming in? I am running out of ideas. Please help. I am using 2013 AIM
thanks
Julie
P.S. the car shown in the attached jpg is really a building
Are you using the Draw Strip to insert City Furniture? If so, to insert a model, you double click to place the model in the view.
I am using the draw strip and I am double clicking. After I do that it spins for a while like it is about to place it, but then nothing.
Perhaps a bad install? Not sure. It should work by what I mentioned above.
