Hi, I have imported a SHP file generated from GIS package of building footprints with elevations generateds from contour info, then used the properties to assign a height and roof slope for those building footprints. they all sit on top of a surface created from contors. One or 2 of the buildings where still hovering a little over the surface, I tried selecting those buildings individually and tried to find a transform option to lower or raise them but couldn't find anything, can you put me in the right direction.
Solved by tcorey. Go to Solution.
If you pick the building you should see a UCS Icon. If you don't see it, right click and select Edit. Pick the Z axis to slide the building up and down.
Working late? Usually my evening posts don't go answered until the next day.
