InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Cannot split a road
8 REPLIES 8
Message 1 of 9
odoshi
2250 Views, 8 Replies
Cannot split a road
When I click the Edit existing Features tool, then seelct my road and right click, I do not have Split as an option on the menu.
Docs say you can split a road at any time.
Am I missing something?
Thx!
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
8 REPLIES 8
Message 2 of 9
ToddRogers-WPM
in reply to: odoshi
Are you in "edit" mode?  You have to be in edit mode.
Todd Rogers
Message 3 of 9
odoshi
in reply to: ToddRogers-WPM
Yes, I clicked the second icon in the vertical toolstrip, with the pencil. (Create Edit Features)
Then the Edit / Draw toolstrip appears and I select the frist icon, and select my road. All the edit gizmos appear but the right-click does not contain Split, only Add Point, Recreate Profile, Road Properties and Exit Edit Mode - which to me says I am in Edit Mode.
Maybe it is the Ultimate version plugins, messing with the context menu? Profile options are not included in Standard and Premium, I don't thnk.
Mike Caruso
Message 4 of 9
odoshi
in reply to: odoshi
I;ve noticed that I can open some sample models and Split their roads, but not mine. Even if I add a road to the sample model, my new road will not split, but the existing roads will.
Anybody know what I am missing. Help docs are worthless...
Mike Caruso
Message 5 of 9
ToddRogers-WPM
in reply to: odoshi
If it is a "design" road, you do not have the option to split it.  If it is just a "Create Roads [Road]", you have the option to split it.
Todd Rogers
Message 6 of 9
odoshi
in reply to: odoshi
I've seen the terms of Sketch vs Design, but from the UI, how do I know which is which?
And is there a way to go back from a Design road to a Sketch road?
Mike
Mike Caruso
Message 7 of 9
ToddRogers-WPM
in reply to: odoshi
I tried a few different options and was unsuccessful in doing so.
Todd Rogers
Message 8 of 9
BrianHailey
in reply to: odoshi
Mike
Just thinking outloud, perhaps you could export the .imx file, bring it into C3D, export that as a .shp or .sdf file, and then import that as a road?
Seems like a lot of work but that's the only thing I can think of currently.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 9 of 9
martin.folber
in reply to: BrianHailey
I really dont understand why split command was removed in "road and highway module". It is very useful command if anybody wants to exchange one style for the second style. Typically just to draw two collinar roads with gap for a bridge. It is question, when these commands are missing, if it is worth to use it. Also snaping doesnt work correctly...:(
Rail Community
