InfraWorks General
Employee
Message 11 of 16 (574 Views)
Re: Autodesk Infrastructure Modeler error
08-02-2012 02:53 AM in reply to: Metsihafe_M
Hello Peter
I am sorry to hear this. We reopend the corresponding defect and will try to find out by what other product this can also be caused.
Heiko Meyerdirks
Engineering Manager
Autodesk IPG ICP InfraWorks
Member
Message 12 of 16 (571 Views)
08-02-2012 06:18 AM in reply to: heiko.meyerdirks
It is solved for me. Except my adobe is giving some warning.
Metsihafe M
Metsihafe M
Employee
Message 13 of 16 (567 Views)
08-02-2012 07:39 AM in reply to: peterwitjes7473
Hi Peter,
Can you do a thorough search of your hard drive and registry for both acaptuser64.dll and acaptuser32.dll, to make sure some other product did not install any version of those? It's worth double checking this because it has solved the problem for all other people that we know of with this problem.
Traian
Active Member
peterwitjes7473
Message 14 of 16 (558 Views)
08-03-2012 12:35 AM in reply to: heiko.meyerdirks
Hi Traian,
I've just twice checked everything. The registry and hard drive gives no result for acaptuser32.dll and acaptuser64.dll.
In the registry I also looked at the CheckedValue key in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL was set 1 to ensure that all folders are shown. After that I checked the registry and hard drive again, but no results.
Sorry, but no results
regards,
Peter
Valued Contributor
Message 15 of 16 (468 Views)
09-11-2012 01:26 PM in reply to: peterwitjes7473
Remove the 64bit addon worked for me too. Thanks
Active Member
peterwitjes7473
Message 16 of 16 (447 Views)
09-17-2012 02:00 AM in reply to: PatrickManson
Finally .... it works. The problem is the Windows 7 version. I bought a new W7 pro version and installed everything again, and it works.
In an earlier state I installed the pre-installed W7 home premium version and the problem resist. So, after all the other solutions that I tried the last option for me was to buy a new windows 7 pro version.
You are not logged in.
Ask the Community
