InfraWorks General
Member
Message 1 of 16 (1,326 Views)
Accepted Solution
Autodesk Infrastructure Modeler error
1326 Views, 15 Replies
07-10-2012 01:18 AM
I have installed the new software - Autodesk Infrastructure design Suite. All products works except Autodesk Infrastructure Modeler.
I have problem on when I open AIM 2013. Every time I am trying to open file from inside AIM , I can't see names of folder and files. (See the attached files)
I have been in contact with Autodesk but their assistance has not solved the problem yet and now the case is forwarded to the Autodesk development team to analyze the reasons for it.
Any assitance.
Metsihafe
Window 7 ultimate Dell Precision T7400- 64bits
Metsihafe M
Member
Message 2 of 16 (1,321 Views)
Re: Autodesk Infrastructure Modeler error
07-10-2012 03:51 AM in reply to: Metsihafe_M
sorry for the misising attached files.
Metsihafe M
Active Member
peterwitjes7473
Message 3 of 16 (1,298 Views)
07-14-2012 01:22 AM in reply to: Metsihafe_M
I have exactly the same problem.
I've reinstalled Windows 7 64bit, reinstalled AIM, replaced the Garphic card nvidia GT530 for a nvidia quadro 2000. Nothing helped so far.
Hope they soon solve this problem
Peter
Employee
konstantin.baumann
Message 4 of 16 (1,278 Views)
07-20-2012 07:16 AM in reply to: peterwitjes7473
we are working hard on investing and fixing this issue...
Employee
Message 5 of 16 (1,262 Views)
07-23-2012 11:03 AM in reply to: Metsihafe_M
It might help to try running the Windows System File Checker to make sure there aren't any corrupted system files (for example system font files). From a command line run:
sfc /scannow
More information here: http://support.microsoft.com/kb/929833
Employee
Message 6 of 16 (1,259 Views)
07-23-2012 11:57 AM in reply to: tstanev
And another thing to try would be to switch the application color scheme to "Light" in the Options dialog (accessible from the application button on the top left).
Active Member
peterwitjes7473
Message 7 of 16 (1,250 Views)
07-23-2012 10:11 PM in reply to: Metsihafe_M
I have already tried sfc en set the color scheme to light, but that wasn't the solution. I've googled this issue and also changed some foldermap settings and permissions. No results so far.
Our AutoCad Reseller is also informed by me and they are also looking for a solutoin.
Thank you for your time and hope that somebody can solve this problem
Employee
Message 8 of 16 (1,220 Views)
07-31-2012 06:15 AM in reply to: Metsihafe_M
We finally found one fix which already worked for one customer facing the same issue:
You need to remove the “Adobe 3D Capture element” or the "Adobe Acrobat 9 pro extended 64-bit add-on"
If you have installed Acrobat X, you will not see Adobe 3D Capture as an installed program. One customer facing the same issues had "Adobe Acrobat 9 Pro Extended 64-bit add-on" installed instead but found an related registry entry
[HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Adobe Acrobat\9.0\Installer]
"AppInit_DLLs"="acaptuser64.dll".
As it seems, acaptuser64.dll caused the issues at the customers machine. After uninstall of “Adobe Acrobat 9 Pro Extended 64-bit add-on", AIM worked like a charm.
I very much hope this will help you as well.
Heiko Meyerdirks
Engineering Manager
Autodesk IPG ICP InfraWorks
Active Member
peterwitjes7473
Message 9 of 16 (1,217 Views)
07-31-2012 06:42 AM in reply to: heiko.meyerdirks
Heiko, Thank you very very much. I am not at work at the moment, but when i am there i will try this directly. Hope this is the solution Best regards, Met vriendelijke groet, Peter Witjes medewerker Vastgoed Team Openbare Ruimte en Vastgoed Gemeente Zevenaar Bezoekadres: Kerkstraat 27, 6901 AA Zevenaar Postadres: Postbus 10, 6900 AA Zevenaar T: (0316) 595 324 W: www.zevenaar.nl
Active Member
peterwitjes7473
Message 10 of 16 (1,191 Views)
08-01-2012 10:43 PM in reply to: Metsihafe_M
Heiko,
Both software products are not installed on my computer. I've checked the registry if I could find anything. So, it didn't solve my problem. If you have any further recommendations, then of course I liked to hearthem
Thank you so far
regards,
Peter
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
