I'm trying to create a road going through a vineyard. I'd like to use the PNG image format to create the effect of grape vines using an alpha channel and image texture. Everytime I bring the PNG format into Infraworks I cannot see the alpha channel transparency, only the RGB channels show up. How can I get the alpha channels to work on imported material images?
Solved by DavidMettler1819. Go to Solution.
FYI... Failed to mention that I saved the PNG with a transparent background
Found a workable solution using DDS format exporting out as DTX5 8bit rgb with interpolated alpha.
