InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Terrain & Raster Not Appear Properly
3 REPLIES 3
nrdamayanti
725 Views, 3 Replies
Hi..
I'have terrain and raster at same position. When I opened raster only or terrain ony there's no problem at all. But The visual appear not properly when I load both, raster and terrain.. As attached..
Does anyone know what the problem is?
Kindly need your advice all..
NRDamayanti
3 REPLIES 3
does that always appear like that or is it depending from the direction of sight/the camera-height/...?
If it depends on images you might try to change the format of the image, e.g. if you have uncompressed TIFF's try to convert them to LZW-compressed ones or to JPG's (be careful in that case with your georeference world file: TFW has to be changed to JGW).
Another option is to change the 3D graphics settings within your IW, play with these settings:
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
lippola
in reply to: nrdamayanti
Hi there this is pretty bad. Can you provide the two files so we can have a deeper look.
Thx
Andreas
Varhun.Prasad
I can honestly say that is a graphics card problem (not sure if its a driver issue or hardware though).
I have two machines, exact same specs but one has a Quadro k1000 1GB and the other is a Quadro k2000 2GB. On the machine with the 1GB card I had this exact problem. It would drape fine but once you start moving the model around this happens. The same model on the 2GB machine works a charm.
Try that same model on another, better spec'd machine, and see what happens.
Varhun
Varhun
Rail Community
