Is there a way to recover a corrupt infraworks file?
I was working on a model that crashed while I was changing road styles. When I opened the model back again, I get the error report window. I have already restarted the PC. Opening a different model is fine.
Is there a backup file created similar to the .bak file for dwg files?
Thanks.
It doesn't give any details of the error. It goes straight to the Error Report sending window after a second or 2 of clicking the model. It just says "A software problem has caused Autodesk Infraworks 2014 R2 to close unexpectedly"
The error log:
161 [3824]: main.cpp(165): info: logging started in: C:/Users/Harold-Mao/AppData/Roaming/Autodesk/InfraWorks 2014 R2/logs/AIM_2013-10-22_20-08-44_0000.log
163 [3824]: AlxApplication.cpp(706): info: init application locale using: 'en-US'
171 [3824]: AlxApplication.cpp(825): info: Using resource data folder: C:/ProgramData/Autodesk/InfraWorks 2014 R2/Resources
171 [3824]: AlxApplication.cpp(835): info: Using user data folder: D:/Harold-Mao/My Documents/Autodesk InfraWorks Models
1113 [3824]: Core.cpp(41): info: using GDAL data path: C:/Program Files/Autodesk/InfraWorks 2014 R2/\gdal_data
1253 [3824]: AlxApplication.cpp(461): info: AlxApplication: Initialized!
4244 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_CommentsFeed.aimplugin.dll
4432 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_PathOptimizationUI.aimplugin.dll
4716 [3824]: ActionManager.cpp(50): warn: Action 'ID_Window_ProfileView' has already been registered -- will replace.
4717 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_RoadsHighwaysUi.aimplugin.dll
4727 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_RT.aimplugin.dll
4734 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_Scenario.aimplugin.dll
4848 [3824]: AlxApplication.cpp(602): info: Loaded plugin: AIM_Service.aimplugin.dll
Same is happening to me
Neil,
What caused the crash?
I had one again today just changing a road style from the properties palette. Previously I was drag and dropping a road style from the Style Pallette to the proposed road.
I found this thread and followed the steps but didn't work.
http://forums.autodesk.com/t5/InfraWorks/crash-on-start-up-corrupt-file/td-p/3932402
If you manage to get your model fixed somehow please let us know. My model corrupted earlier today when my pc bluescreened and i've lost a lot of work because of it.
Has anyone found a solution for this yet? I am having the same problem. My crash happened when I was tying to add a data source. Now every time I try to open that model Infraworks crashes.
I have tried logging out, shutting down, opening on another computer, and the process described in: http://forums.autodesk.com/t5/InfraWorks-General/crash-on-start-up-corrupt-file/td-p/3932402 but nothing has worked.
I'm about ready to recreate the model unless anyone has a solution.
I've had a lot of crashes that always seem to force me to delete a lot of content and start again, and sometimes it deletes content for me. Usually happens a lot when i am changing styles on buildings, adding roof materials, and sometimes it happens when i am playing with road geometry. When it crashed hard on me today, the aerial photo and terrain model weren't loading properly, it had deleted out half the buildings i had added, all the street light furniture, and one of my main roads!
Does anyone have a fix for when this happens? I'm trying to get this to work so that I can demo it for my department to use it for proposals, but i'm starting to think it might be a few years away from being ready if i am constantly, on a daily basis, losing time when i have to constantly redo work. I think the program crashed on me about 10 times this morning just reskinning a building before the big crash that set me back 2 days.
