All,
We have an issue opening AIM 2013, when we double click the shortcut we get the following pop up... see attached image. Has anyone come across this?
The procedure entry point ?spatialOp@ExprBuilder@fdo@@QEAAXW4SpatialOps@12@@Z could not be located in the dynamic link library FdoWrap.dll
Solved by ToddRogers-WPM. Go to Solution.
I started getting this message before I installed R2. Apparently it really doesn't affect anything. Click OK and continue.
That's a bummer. My suggestion would be to log into Subscription website and download AIM R2. Much better release.
I found that a repair did not work with this issue prior to R2. I had to do a complete uninstall and re-install. I know, it sucks to have to do this.
Is there any Site you can post to find the download of AIM 2013 R2??
Can´t find it in my Subsription-Center.
Firstly, is your AIM version on subscription?
and Secondly, have you spoken to either your "Software Coordinator" or "Contract Manager" for the Subscription Site? It could be that they have blocked access for users to the "Product Enhancements" section which is where you will find the info for AIM R2.
AIM R2 2012-10-04
Hope that helps 🙂
Duncan
Yes it is in Subscription an i am the Software Coordinator ;D
Thanks, for your help, in the meantime I managed to find the right path.
Best Regards, Kai
