InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks 2014 - Component of Autodesk Infraworks 2014 has stopped working.
26 REPLIES 26
Message 1 of 27
david.lau
3008 Views, 26 Replies
When starting Infraworks - I get this error:  Component of Autodesk Infraworks 2014 has stopped working.
AIM 2013 also has the same error.
AIM 2012 does work.
Coult this be the issue?
http://forums.autodesk.com/t5/Autodesk-InfraWorks/AIM-2013-not-opening/m-p/3823563
David Lau
26 REPLIES 26
Message 2 of 27
DarrenP
in reply to: david.lau
it could be
i can't seem to log in to AIM 360 account from Infraworks 2014 but starts up fine
with 2013 yes that could be the problem if your using 2013 r2 there is this hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20979998&linkID=17838076
DarrenP
Message 3 of 27
lippola
Hi guys,
just wonder if this has been resolved or if new information on this issue came up?
Andreas
Message 4 of 27
DarrenP
in reply to: lippola
no idea
DarrenP
Message 5 of 27
enelson
I am currently having the same issue.  Worked yesterday morning, then tried it in the afternoon and it stopped.  Did anyone find a solution for this?
Erik Nelson
Win 10 64-bit, 1TB SSD, 128gb DDR4 Ram, AMD 24 Core Threadripper, NVIDIA GTX2060
Message 6 of 27
vaderdarth
Has anyone or Autodesk found a solution.  I can't even start this program.
Message 7 of 27
david.lau
Can you let me know if Infra Structure Modeller 2012 worked?
When the 2013, 2014 version came, the application was rename to aim.exe which is the same as AOL messager which may be a banned program in company.
http://forums.autodesk.com/t5/Autodesk-InfraWorks/AIM-2013-not-opening/m-p/3823563#M692
Other than that, you need to also confirm that your video card is supported as well.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18630064&linkID=17838075
http://docs.autodesk.com/ICD/2014/ENU/system_requirements/infraworks-sys-reqs.htm
David Lau
Message 8 of 27
enelson
I uninstalled my video card and reinstalled it, the program opened as normal.  I recently dumped my old Nvidia cards in favor of an AMD Firepro, seems to really do the trick.  But if you are having this problem, try to unistall and reinstall the video card and drivers.
Erik Nelson
Message 9 of 27
TCARCAMO78
in reply to: enelson
I am having the same issue also. InfraWorks 2014 r2 was working fine for the first 2 days then windows did some updates and now it's crashing as soon as I open it. I get the same message that Infraworks component as failed. I have uninstalled it then reinstalled and it still does not work. Am going to try to revert my video card update to see if thats is the problem.
Tony
CAD Manager
AutoCAD Civil 3D 2013 Certified Professional
www.tonyscivil3dworld.blogspot.com
Tony Carcamo
CAD Manager
Message 10 of 27
vaderdarth
2013 worked fine, and all the rest of the ultimate building suite 2014 works just fine.  It is just the Infra Structure that is not opening and coming up with the message.  It seems strange that Autodesk would re-deisgn or program a piece of software that all the sudden needs different video requirements then the rest of the package.
Message 11 of 27
vaderdarth
2013 worked fine, and all the rest of the ultimate building suite 2014 works just fine.  It is just the InfraWorks that is not opening and coming up with the message.  It seems strange that Autodesk would re-deisgn or program a piece of software that all the sudden needs different video requirements then the rest of the package.
Message 12 of 27
vaderdarth
in reply to: vaderdarth
Note this is not Infra Structure, but is InfraWorks
Message 13 of 27
ladams
I am also getting the same message. I started a new project in Infraworks 2014 R2 and while I was making edits to a road, it crashed. Now I am unable to open the file at all. It is as if that file is now corrupt. My computer meets all the requirements for the software.
Message 14 of 27
Robert_Boss
I'm experiencing the same problem. I wanted to evaluate the trial version of AIM 2014 and it installed without errors, but at startup it crashes. From the event log I get the following message ;
Faulting application name: AIM.exe, version: 3.0.0.5006, time stamp: 0x512c3d3f
Faulting module name: ntdll.dll, version: 6.1.7601.18205, time stamp: 0x51dba4e7
Exception code: 0xc0000005
Fault offset: 0x000000000005339d
Faulting process id: 0x1698
Faulting application start time: 0x01cea03144acd7a2
Faulting application path: C:\Program Files\Autodesk\InfraWorks 2014\AIM.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 8563c47c-0c24-11e3-a648-082e5f7499c4
I'm running Win 7 with a Nvidia GeForce GT 650 graphic card (driver ver. 320.49) on an HP Pavilion dv 7 notebook.
Anybody have any ideas?
Thanks in advance !
Message 15 of 27
TCARCAMO78
Ok I got mine to finally work again. I had to do a complete uninstalled of my video drivers which defaulted back to my onboard vga settings. Then I did a complete reinstall of my nvidia video drivers. Everythings seems work now.
Tony C
CAD Manager
Tony Carcamo
CAD Manager
Message 16 of 27
jukka.alander
in reply to: TCARCAMO78
Same problem, same solution. With Nvidia driver 320.49 works fine but 320.78 crashes IW.
Message 17 of 27
guyhache30
Same for me... Using a Gtx 760 (driver 9.18.13.2680), and when I install the software Nvidia Experience it wont start.  I remove the software and it work but crash when I try to do a Render...  I gonna try to downgrade my driver see if it works...
Message 18 of 27
Stiklins
Having the same problem !
Downloaded latest version of InfraWorks, and introduction to soft stops at startup screen - Component of
Tried changing graphics driver (nvidia quadroFX 580) without results.
Is there came out some unique solution, or at least more clearer reason why its hapening?
Message 19 of 27
jaturner
I am having the same problem.  Worked on it all day yesterday, it worked fine.  then this afternoon I started it up and it won't finish opening.  Error message that says "A compomnent of Autodesk Infraworks is not responding"
Message 20 of 27
jukka.alander
in reply to: jaturner
Try downgrading nvidia display driver, it seems to help. Anybody with Amd GPU having this problem?
Rail Community
