If I design a pad in InfraWorks, is there a way to tell the program how far out to go to daylight to OG? For roads, it's in the road style, but I can't find how to adjust this for pads.
Tim
Tim,
If you are using a Coverage object, you can control the width using the object's Smooth Radius property. If you are using a Land Area object, you can control the width or the slope using a Grading object (found on the Grading tab of the STYLE PALETTE) - drag and drop the Grading onto the Land Area, or set the Land Area's Manual Grading property.
Bill Dhimitri
InfraWorks Team
Thanks, Bill. I figured that out in the year since I posted that question. 😉
