Does anyone know if I can create a floodplain in Infraworks, and how to assign a water style to it?
I can make a shape file, but will I loose the water surface elevations in the translation of it all? I also have triangular faces with elevations. Ultimately I would like to use a surface as the Floodplain, and stylize it with water. Is that possible? Thanks!
You might try the steps below.
Create a large transparent blue plane by copying an existing plane and scaling it:
Add the plane to your model, and set the Elevation value (this represents the level of the water):
The images below show the result:
Bill Dhimitri
InfraWorks Team
Thank you for your solution, will this also work with the version of Infraworks that comes with the 2014 Premium IDS? Our company has not yet upgraded our subscription, so I don't have R4 available yet.
Yes, it does.
I just tried it in Infraworks 2014 R2 and it works fine.
