I want to be able to draw a temporary road "on-top" of my 3D-model. I don´t want it to be a road design (then Infraworks is making intersectiones) but just a colored/filled polygon laying on top of everything. Is that possible?
I´m afraid that coverage areas is drawn under my existing roads. That is not working for my purpose of temporary roads.
You can use the grips to move it above the road. You can use a road and do the same thing.
Stupid as I am. I can´t make it work. As I raise the coverage area the roads follow up. The roads are always over the coverage areas. Is it the grips in the corners I should use? I don´t think there are any others.
Actually that's my bad. You need to use the 3D Gizmo to move the coverage above the road...
It's blue, but when you hover on it, it turns red like in the picture.
