InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Displaying Rivers
4 REPLIES 4
BrianHailey
1222 Views, 4 Replies
Displaying Rivers
So, if you have a .shp file representing the flowlines of rivers and streams, what's the best way to display that? Water areas don't work, right? They have to have an enclosed area and all I have is the flowline of the streams. Create a road style that looks like a river? Any other ideas?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
4 REPLIES 4
You are correct.  You  have to have a closed area for the water style.  And you are also correct in that you could create a road with a "water" surface.  You can grab a picture of water off the internet and assign it as a material.  Should work for you.
Todd Rogers
There is an easier solution to this: when importing the data and after selecting the target type "Water area" there is this field "Buffer width": this can be used to turn the line string/polyline into a polygon. This field can be either mapped from the imported data or set to a constant value. and then you can chose an appropriate water style.
And a remark to the water surface: you can also use the special "water shader material" (dynamically animated and reflective) as material for the different street track materials; there should be no need to import your own water texture.
Konstantin.B
Software Architect
Tags (1)
The buffer width works like a charm! Now if only my dataset had the width of the stream in it.
GEI Consultants
My Civil 3D Blog
in reply to: BrianHailey
Hi Brian , I just did the suggested method using buffer width. I was wondering if you found a way to update your database with the current river width.
Rail Community
