InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Concrete Mixer on incline
4 REPLIES 4
neilyj666
1352 Views, 4 Replies
How can I angle a concrete mixer (or any vehicle) to show it on a slope? At the moment the front wheels are either above the road or below it
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
ToddRogers-WPM
in reply to: neilyj666
Create a coverage area.  After it is created, you can adjust it with the grips.
Todd Rogers
neilyj666
in reply to: ToddRogers-WPM
Thanks for this but I'm not sure how it helps to tilt the concrete mixer?
NateMoore
Pick the mixer, right click and select properties. Use the Rotate options (probably X) to get all the wheels on the same plane as the ground. You 'll probably need to tweak the Z after that.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
neilyj666
in reply to: NateMoore
Thanks Nate - worked perfectly
Rail Community
