In Infrtaworks I get error that says the loginmanager has timed out when I try in sign into Autodesk 360. I have attached a screen shot of the error.
How do i fix this?
Thanks in advance
Scott
Solved by civil3djedi. Go to Solution.
Have IT check for the correct ports to allow Autodesk 360 to communicate. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22742740&linkID=17838075
I think this needs to be opened at the firewall.
((standard 80 and 443 (https))
