Having a real issue installing the AUtodesk 360 Add On, Normal installation of standard AIM 2013 loads and works fine as soon as i install Autodesk Infrastructure Moddeller Add On AIM will not load just hangs on a blank white screen, i have tried diffrent install etc but to no avail, anybody else havethe same issue
Bit of a schoolboy error, just need to ensure that you are signed out of Autodesk 360 should you have an account for other reasons, as soon as signed out everything loads fine
i can't even get to that point
seems to be a major bug with the add in
DarrenP
this is still a problem with the new infrastructure modeler extenstion
DarrenP
