InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Alpha Channel for PNG files??
2 REPLIES 2
DavidMettler1819
1277 Views, 2 Replies
I'm trying to create a road going through a vineyard. I'd like to use the PNG image format to create the effect of grape vines using an alpha channel and image texture. Everytime I bring the PNG format into Infraworks I cannot see the alpha channel transparency, only the RGB channels show up. How can I get the alpha channels to work on imported material images?
David Mettler
Haydon Building Corp
dmettler@haydonbc.com
2 REPLIES 2
FYI... Failed to mention that I saved the PNG with a transparent background
David Mettler
Found a workable solution using DDS format exporting out as DTX5 8bit rgb with interpolated alpha.
David Mettler
Rail Community
