After installing AIM 2013 R2, the tool tip no longer includes the "Show Motion Panel" button. Is this normal? If so, how do you specify a camera path? If not, how do I get it back?
Solved by ToddRogers-WPM. Go to Solution.
The ShowMotion panel is gone. It is now creating a Storyboard. It will take you a bit to get used to it, but it's actually pretty cool once you get the hang of it. You can check out what it does in my blog...
http://civil3dj.wordpress.com/2012/10/22/see-the-result-of-autodesk-infrastructure-modeler-2013-r2/
Ahhh.. got it... very showcase-esque 😉
Many thanks.
