InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
3D Tree Transparency problem load into Infraworks 2014
3 REPLIES 3
yjnh2006
661 Views, 3 Replies
Hi
I have created very simple 3D tree by using only two orthogonal planes, the tree image is already transparent.
But when I load into infraworks, it is very wired.  See the two images attached.  One for original tree image and the other for tree model load into Infraworks.
Any idea how to solve this problem.
Tom
3 REPLIES 3
ToddRogers-WPM
in reply to: yjnh2006
The fix to this is in the thread located here.
Todd Rogers
yjnh2006
thanks for the message, but what I want is shown in attached file, it is working fine in Autodesk Maya , why not working in Infraworks.
Tom
daniel.bruce
Is the tree transparency set by the Alpha channel? Also, are importing the model into infraworks as an FBX?
If this is the case FBX does not support the Alpha channel. There are other ways to acheive the transparency eg using a cut out.
Rail Community
