It is likely related to the gap tolerance - either the Impression area fill setting, or how closely the lines are closed in your target DWG. If the lines surrounding your fill area aren't touching, that may be the problem. Try increasing the gap tolerance, or manually closing the lines around your to-be-filled areas in Autocad before importing into Impression.
thanks,
shana
