Impression (Read Only)
Impression on Vista 64?
9 REPLIES 9
Message 1 of 10
811 Views, 9 Replies
I saw the note in the FAQ about Impression on Vista 64 not being "optimal". I am curious as to what exactly this means and if a 64 bit version of Impression will be released?
MK
9 REPLIES 9
Message 2 of 10
ShanaProd
We're not currently planning a 64-bit release.
That said, we did moderate testing on Vista64 and while it's not supported, you should be able to use Impression on it. Let me know if you run into Vista64-specific issues.
thanks,
Shana
Message 3 of 10
Thanks for the response. I like using Impression and can only see myself using it more. I am ready to make the move to 64 bit and am glad to hear that this should work ok.
Message 4 of 10
ShanaProd
Definitely give it a go 🙂 and let me know about any specific 64-bit problems.
Shana
(shana.priwer@autodesk.com)
Message 5 of 10
I'm running it on XP 64-bit and haven't had any problems. Can't image it
being any different on Vista 64-bit
Message 6 of 10
Matt.Anderson
Can't seem to get it to run on Win7 64...rather I can only get it to run the CER for Impression in Win7 beta. I am going to try again with the RC.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 7 of 10
ShanaProd
Definitely try the RC, with the current Impression 3. Please let me know your results.
Shana
Message 8 of 10
Matt.Anderson
Tried that yesterday after loading Win7 64bit RC and Impression 3.
I was able to get a little farther, but somethings like Communication Center, and attempting to save the file - didn't work at all.
There is a CER sent when I attempted to save the file.
anderson at jaseng dot com
Product Manager
Autodesk (Innovyze)
Message 9 of 10
danb4026
I cannot get Impression 3 to open files on Vista 64. The program itself runs, but when I go to "file", "open", I get an error message that "impression.exe" cannot be found, make sure target is correct. It says to right click on the icon and click properties and check target path.
Not sure why this is happening.
Message 10 of 10
Please install netframework SDK 3.5 SP1........specifically these files
after installing 3.5SP1 install the below and u will be able to use impressions on vista 64 without a hitch. google the below
NDP35SP1-KB958484-x64.exe
Windows6.0-KB957542-v2-x64.msu
Windows6.0-KB958481-x64.msu
Windows6.0-KB958483-x64.msu
