Impression
Active Member
deane
Message 1 of 24 (3,971 Views)
Impression 3 - Constant Crashing!
3971 Views, 23 Replies
03-17-2011 05:20 AM
We're coming to our wits end using Impression 3... It is now crashing more often than it ever has.  This problem is on multiple machines with multiple files.  These are only 2-5 MB files, that are in FAST DISPLAY,layers and blocks purged, all layers grouped, all other programs closed, and the hotfix installed.
MACHINE SPECS:
-Windows 7 64-bit
-Intel Core 2 Quad 2.4 GHz
-8.00 GB RAM
-NVIDIA Quadro FX 1500
Crashes While:
-Panning 'too quickly' (WORST OFFENDER)
-Using line or rectangle tool
-Importing Blocks
Other quirks:
-After several crashes, Impression 3 refuses to launch when clicking on .irf file in windows explorer.
-Layers display in a different order than how they are truely stacked.
PLEASE HELP IF YOU HAVE HAD ANY OF THESE ISSUES AND SUCESSFULLY FIXED THEM!!!  Has AutoDesk given up on Impression or will there be a future release with these problems resolved?
Valued Contributor
TexShalter
Message 2 of 24 (3,939 Views)
Re: Impression 3 - Constant Crashing!
03-23-2011 06:25 AM in reply to: deane
I find it to be a VERY graphic intense program - even with quick view.
Be sure you have sufficient ram, a decent video card, and by all means don't run other big programs while using impression.
I've had some luck saving the styles needed and then opening the cad file from scratch again. ( not updating cad geometry to many times)
Also, try a reboot just before starting.
Member
GaryMarkham2113
Message 3 of 24 (3,907 Views)
03-29-2011 07:57 AM in reply to: deane
I had this happen and with the same sort of spec machine... except it's a 32 Bit machine. The problem we found was Windows 7, I contacted Autodesk and sent me a hot fix, which you need to up date 2 application extensions. the Custom Controls and the UILib extension.
If your stuck let me know and I will send you what I was given.
Active Member
deane
Message 4 of 24 (3,900 Views)
03-29-2011 08:11 AM in reply to: GaryMarkham2113
See even with the hot fix I've found it to be a huge problem.  Its most definately having to do with stretching or creating any line/fill type that has modeling/irregularity to it.
Its really too bad because the frustrations we're all feeling in our studio are leading to exploration of other software packages...
I'm very suprised Autodesk doesnt seem to care.
Valued Contributor
TexShalter
Message 5 of 24 (3,896 Views)
03-29-2011 08:22 AM in reply to: deane
Dear Gary,
If Autodesk sent you an unpublished hotfix, could you please share it with of us here.
Thank
Member
GaryMarkham2113
Message 6 of 24 (3,893 Views)
03-29-2011 09:07 AM in reply to: TexShalter
Due to our Internal security, i'm not allowed to attach items to blogs etc.. but post your email and I will send it directly, so you can post it.
Regards
Gary
Active Member
deane
Message 7 of 24 (3,891 Views)
03-29-2011 09:09 AM in reply to: GaryMarkham2113
I'd love to recieve it as well if you wouldnt mind forwarding it to:
deane@slamcoll.com
Thanks so much!!!
Valued Contributor
TexShalter
Message 8 of 24 (3,871 Views)
03-31-2011 12:17 PM in reply to: deane
Dear Gary,
Here is my email, hope I can return the favor someday.
rtull@rtull.com
Tex
New Member
nrschmid
Message 9 of 24 (3,859 Views)
04-02-2011 08:55 AM in reply to: deane
Can you also email me, too?
Thanks-
gymratbookworm@yahoo.com
Member
heatherpell3919
Message 10 of 24 (3,387 Views)
01-16-2012 08:20 AM in reply to: deane
Would you please send it to me as well? hpell@lunz.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
