Impression (Read Only)
Error importing DWG Layout Files
1 REPLY 1
Benway802
1869 Views, 1 Reply
I can't seem to open DWG file i exported from REVIT after i touched it up in Autocad. I have impression 3. I get through picking all the otpisons and then a error pops up saying it can't be imported but it is an Autocad DWG file. Also i tired saving it as a 2007 DWG and still got nothing. I coul dopen the filel before i touch it up in Autocad but the hatches/fills are pink and view port lines show up.
1 REPLY 1
pendean
in reply to: Benway802
Try using _EXPORTTOAUTOCAD command in AutoAD to truly knock the file down to 2007 format and try again.
Otherwise whatever it is you added is stopping the app from accessing your file.
