I'm trying to use a model downloaded from the Gallery page but haven't found how to use it in Fusion because you can't load local files. What is the trick?
I looked around and didn't find any exact answers
Hello if you had downloaded the .f3d file you can import into Fusion360. Click on the Upload tab on the Dashboard and select to Import CAD data from local drive.
Just wait for email and message from Fusion after that. Hope it works for you.
