hello
i am new to fusion 360..i saw many tutorial and tried to learn..but there is one thing i dnt get at all..in one tutorial..the person creted a lamp..he used MOVE cammad to adjust a one side..but when i try to do it..the whole body gets selected and whole body starts to move..please help me..i am confused
Solved by innovatenate. Go to Solution.
In order to use the Move Command on faces, you need to first Create a Base Feature and enter Direct Edit mode.
Note the difference in behavior for the move command for the following procedures:
Compare to Direct Edit behavior:
I hope this helps. Please let me know if you have any questions.
