import stuck in progress
11 REPLIES 11
Message 1 of 12
big_red_frog
1716 Views, 11 Replies
Hi There,
I was attempting to import a massive step file that I really should not of tried.
It is now stuck in about 60%, and has been for 3 days, during which time I have variously had fusion open.
I want to abandon this import, but see no way to do it.
I have other imports to execute, but they queue up behind with "Import-Waiting"
How do I cancel / abandon the "bad" import?
Thanks.
11 REPLIES 11
Message 2 of 12
big_red_frog
in reply to: big_red_frog
It looks like this import which no longer progresses ( original step file was 500 Meg! ) may be blocking other cloud functionality as well.
I can see my internet UL stays running at max rate throughout a session, and on attempting to close the package it is waiting forever.
I do not yet know if this blocks updates to models that were being edited, or if they get prioritised.
Message 3 of 12
garin
Let me send this to our cloud folks and see what's up. I am sure we can hear back from them in the morning.
Message 4 of 12
garin
in reply to: garin
I sent you a direct message with what I think is a solution to your issue. Try it out and let me know if its works for you.
Message 5 of 12
CCIT_MPn
in reply to: garin
Hi, I got exactly the same issue.
Tried to open a massive .ipt file (500Mb), and now it's stuck.
How to abort the import ?
Message 6 of 12
AndrewSears
in reply to: CCIT_MPn
All,
I always hear from customers about the desire to have a cancel option for various functions such as importing files when you don't know the filesize or after creating patterns when you accidentally added another zero to the quantity.
This was posted in the idea station.  Assembly Import enhancements - file size calculator and cancel command (Thanks Nate!)
If this is what you are looking for give it a kudo.  If you need to expand on this add a comment with the functionality you are looking for.
Andy
Message 7 of 12
garin
I sent you a private message that should help out, let me know if this helps.
Message 8 of 12
I have a same problem. It's a 600KB STEP file.
Kudo sent...
Message 9 of 12
big_red_frog
Message 10 of 12
big_red_frog
The solution for me was to uninstall completely including any temporary file areas. Nothing else would resolve.
As much as this sounds atomic it was relatively quick and painless, and the cloud nature meant otherwise I lost nothing.
As much as a cancel is a good missing feature, having a non recoverable, functionally blocking, upload scenario should be considered a nasty bug, so hopefully can be addressed outside of "feature priority"
Message 11 of 12
garin
Sorry for the pain of clearing this out. Glad you got it working although not an easy solution. You will probably be happy to know that our next update should include a job progress indicator with the ability to cancel any job/s you no longer want.
Message 12 of 12
Thanks! The uninstall (with temporary files) is solved.
