Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
how to do this Inventor model in Fusion
15 REPLIES 15
Message 1 of 16
cekuhnen
507 Views, 15 Replies
It is a pretty simple design but I seem not to even be able to get the same loft with rails in Fusion.
Any tip?
https://www.youtube.com/watch?v=msn_6XYxfGk
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
15 REPLIES 15
Message 2 of 16
TheCADWhisperer
in reply to: cekuhnen
Can you attach the file here?
Message 3 of 16
cekuhnen
in reply to: TheCADWhisperer
Claas Kuhnen
Message 4 of 16
TheCADWhisperer
I experimented with this for a while, and along the way - I have come to the conclusion that Fusion 360 is not ready for a college level classroom.
Message 5 of 16
cekuhnen
Currently I feel the same.
Too many tools and features are just missing to make it not a basic tool.
I was hoping to use it as a new app next semester but I cannot replace Alias with it.
When it comes to surface curvature quality and control Fusion is just limited.
The T-Splines and Designtime line I think is strong.
Claas Kuhnen
Message 6 of 16
cekuhnen
with polygons and then nurbs this shape took me just 2 minutes without the nightmare of sketch planes etc and all this.
That's how I mainly use Fusion for sub-D to Brep work.
Claas Kuhnen
Message 7 of 16
cekuhnen
so the patch tool cannot do it but the solid tool can - go figure ...
works fine as long as sketch constraints dont refuse to work.
Claas Kuhnen
Message 8 of 16
innovatenate
I was able to get this loft to work. I used the Include 3D geometry and some key sketch points in the profiles to insure that I was snapping to the 2D profiles with the 3D splines.  I created a separate sketch for each rail. After that, I had to insure that I was using the Convert to Rails in the Swap option.
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 9 of 16
cekuhnen
in reply to: innovatenate
the solid model has 4 side rails - your model has only two.
how after three crashes after each time redoing the loft with your model can you on your side make a screencast to show me the steps you did for two edges?
Fusion just crashes in such a high way that I gave up. I am not sure I select edges in a way that makes it cranky.
Also the loft tool needs a revised Interface. I need to have ways to edit what are profile edges and what are rail edges for the loft command. Just a selector that counts the amount of edges is not efficient.
Claas Kuhnen
Message 10 of 16
TheCADWhisperer
@cekuhnen wrote:
how after three crashes ...
Fusion just crashes in such a high way that I gave up. ...
Also the loft tool needs a revised Interface....
I am running pretty stable here (Windows 7 OS on an Alienware laptop) - I can recall only one crash in the several weeks that I have been experimenting with Fusion.
The dialog box for Loft is very poor.
Tying sketches together is very poor.  (I couldn't even Project Geometry the endpoint of a spine in one sketch into another sketch.)
Message 11 of 16
cekuhnen
mh then it must be that the OS X port is problematic because Fusion crashes so often it that it discourages me from using with with students next semester. just yesterday with the few testings I experienced 9 crashes.
Claas Kuhnen
Message 12 of 16
Helmi74
there's a good chance the crashes are OS X related. I also get a decent amount of crashes per hour currently no matter if i work on 10.9 or 10.10 beta.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Message 13 of 16
cekuhnen
in reply to: Helmi74
are you a registered dev or how did you get 10.10 beta? grrr ....
I signed up for the public beta but the servers are down lol and I also did not get a dl link - sad face here ...
Claas Kuhnen
Message 14 of 16
innovatenate
I created a ScreenCast that shows how to use the Include 3D Geometry command to create connect 3D spline rail curves for these loft features. I can then use these to generate a Solid or Patch loft command.
I hope this helps.
Cheers,
Nathan Chandler
Message 15 of 16
cekuhnen
now I understand the squeeze you have to use the profiles - the interface is logical here - but you need to know the idea first.
but the include 3d steps again half worked - it seems to be quite buggy.
Claas Kuhnen
Message 16 of 16
cekuhnen
it again does not work as one would assume:
https://drive.google.com/file/d/0Byzv_NlyKp_2ekUxTURSNFdoRGs/edit?usp=sharing
Claas Kuhnen
