hello
i actually wanted to design gears in autodesk fusion 360..is there any tutorial which can teach me how?
thank you
Solved by schneik-adsk. Go to Solution.
You could use a gear generator like the one below. Please note that the below link is not an Autodesk product. Autodesk Inventor has a design accelerator that can perform this task if you have access to it.
http://buildaweso.me/project/2013/12/6/interactive-gear-generator
Once you generate a SVG file with the generator. Create a design in Fusion 360, Create a Sketch, and use the Import SVG command from the Sketch pull down menu. Last, extrude the sketch into a spur gear.
See the below video for details.
https://screencast.autodesk.com/Main/Details/632031e1-f185-4684-9fe0-1ceb451089fa
Hope that helps.
Cheers,
thanks mate..it did help..but i would like to design more different types of gears..like bit of complex one..many gears attach to each other
