Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
creating projects and managing user access.
1 REPLY 1
crfuentes
314 Views, 1 Reply
Hello
I have a question related to importing cad data and sharing in fusion 360
Lets say I import a model into fusion. After the import, will the model be avalible for anyone to download?
Do I have to invite someone first in order for them to download my model?
as I understand, the model can be imported to the servers. But sharing has to be setup and managed via the groups tab in the fusion hub? The model does not simply get uploaded to a repository where anyone may have access correct?
1 REPLY 1
philip.s
in reply to: crfuentes
Hi Carlos!
Designs will automatically be shared with the participants of the group or hub that it was created or imported in. Should you wish to add additional recipients, you can do so by manually inviting them.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
