Fusion 360 started to get crazy (couldn't create sketch from model). I've tried 234234 times destroying old sketches in case of with no luck. I finaly decide to close and reopen fusion 360, but now if i want to open my design the software crash and i can't open it. As you can see beside design 66 to 68 doesn't look good...
Tell me i didn't loose everything...
Ok i downloaded design v65 as a .f3d, reimported back and it opens.
Hopefully i didn't loose too much.
Are all saves going through the cloud? And if yes, can it be desactivated? Here in Brazil ISP still leaves is the f**** middle age, it's expensive and with the same quality i had with my 33.6k in 1995...
EDIT:
It seems there're problems with sketches. Once you have many of them Fusion 360 gets crazy...
You can "Export Archive" from the top left menu in Fusion- this saves a copy to your local drive that you can re-import if things go off the rails. I think if this as a backup if I am doing anything important.
