Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Web function how to
6 REPLIES 6
Helmi74
788 Views, 6 Replies
Web function how to
is there any explanation of the web function yet anywhere? Couldn't find it on the youtube channel or the Learn section here on the website. Looks like i don't quite get how this is intended to be used.
Unfortunately i can't make it to the hangout tonight (well german "tonight" :)) - hope the hangout will be on youtube soon.
Any help on the web function is appreciated.
Thanks!
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
6 REPLIES 6
keqingsong
in reply to: Helmi74
Thanks for the reminder there Helmi. We're planning to create a series of blog post that dives into the new features with more detail, and the web command will certainly be one of those posts. Look at for it in the near future 🙂
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
jeff_strater
in reply to: keqingsong
As a teaser, here is a quickie intro to web.  Think of it as a Rib, but with the Extrude direction in the plane of the sketch.  Very useful for creating grilles or cross-hatched supports.  Just sketch the "top" of the grille inside of a volume (the lines don't need to go to the edges), use Web, select the sketch lines, specify a thickness, and OK.
Jeff Strater
Engineering Director
patrick.miller
There is a video showing how to create webs on the utility knife as well as a reference topic explaining the options available.
http://fusion360.autodesk.com/resources/akn/view/NINVFUS/ENU/?query=web
I'd be interested to know how you went about looking for it in the learning area so I can improve "findability" of content. Thanks!
Patrick
Patrick Miller
User Experience Designer
Fusion 360 Learning
Helmi74
in reply to: patrick.miller
Great stuff, Patrick, thanks.
And also thanks to Jeff - totally missed your post.
Frank / @helmi
@jeff_strater wrote:
As a teaser, ....
Sure would be nice to be able to specify Face Draft within the feature.
Smiley Wink
I completely agree. Much easier to specify draft at creation time than to try to go back and add it later. And more stable, too, since it would be part of the feature, and not a separate feature that would have to track faces.
Jeff
Jeff Strater
