Hi I'm Luis Garcia I have a problem with the last upgrade of the software, when I put a material which is now called appearance my display driver crashed and the same thing happens when I go to render mode. it could be that my computer is failing?
I'm in a Windows laptop, but before the upgrade worked perfectly with the ray tracing view.
Thanks.
Solved by keqingsong. Go to Solution.
Thanks.
Hey Luis! Thanks for reaching out; what you're experiencing was an issue that have been reported multiple times. We have just pushed a fix for this - restart Fusion 360 and you should able to get the update. Let me know if you are still experiencing this after the update.
