Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Tangent Chain Fillet Anomaly
3 REPLIES 3
TheCADWhisperer
574 Views, 3 Replies
Examine the last Fillet feature in the timeline.
I had to select each individual edge even though tangent chain was active.
You can try it on the other side.
3 REPLIES 3
Oh, this isn't good.
If you try to edit the existing Fillet feature the edges that have already been selected are lost (I simply wanted to select the edges on the other side of the part).
I need to look at this with the developers tomorrow. Agreed, something is fishy.
Kevin Schneider
Some good news: our recent bug-fixing in the development build appears to have resolved these ones:
http://www.screencast.com/t/ZhMAP6jt1Tn
(the edit manipulator looks a bit off though... we'll look into that).
These fixes should be in the next update!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
