how do I get the t-spline lines to show up when I create a body like a cube? it does it in the youtube demos but my shapes, torus, box etc show up with a smooth surface with no lines....
Solved by Phil.E. Go to Solution.
You can change a bunch of visual settings using the controls at the bottom of the screen, see below.
Let me know if this helps!
